Cgo3+
Not sure if this has been covers before. After a.crash about 2 weeks ago I keep looking the signal to my camera. It works I get video feed. I can move it most the time but sometime well quite alot now. I can't move it it will start to move then stop if I get to far out of range and I'm only talking about 40 meters up. I'm just wondering if anyone else has had this problem
Dose anyone know how the camera is controlled movment wise? Is it 5.8 or the 2.4?
I believe the 5.8 is for video feed only and the camera tilt and pan are on the 2.4 control channel. It may take some additional testing to locate the problem. You don't have to fly, you can just set the H on a table and walk away while using the camera controls. Also, remove the camera and check the 6 contacts under the H to make sure non of them are depressed.
Polenutrition
