Connecting issue
I use the drone no issues first battery land to change battery for second flight but then will never find WiFi again ?
"then will never find WiFi again ?"
What does that mean? No Breeze-xxxxxx in phone's WiFi setting? Or what never found which?
My first Breeze had a thermal sensitivity problem ( it would overheat easily ) and would not initialize properly after swapping to the second battery.
When powering up after swapping batteries it would make an ugly sound and the Power LED would flash red instead of the normal tri-tone sound and red/green/blue to flashing blue.
If I let it cool off for 20 minutes or so it would work fine again.
Describe the start up sequence you are getting with tones and LED’s at the switch and in the arm.
I get the powering up beeps then a single beep a couple of seconds later
Go to this thread Breeze Troubleshooting Checklist and Help and start with step 2a. Proceed and record results at each step. If you are not able to connect to the Breeze, do the Factory Reset that is described then repeat steps starting at 2a.
If you are still unable to connect, contact Yuneec Customer Support by telephone or online chat on their website. Do not email them as they will rarely get back with you.
Write your reply...
shnippy
