Controller
Recently switched from Samsung Galaxy to iPhone 6. Unable to get iphone to connect with controller. It will barely vibrate but not as much as it did with Galaxy. Screen will read "connected to controller'. Immediately after screen reads not "connected to controller". Bluetooth is turned on but still nothing.
Did you power the controller on using Power+Y to put it in iOS mode instead of Android mode (Power+A)?
Yes. Y and Power for about 2-3 seconds. I was thinking when I hooked to Android there was something on the app that I had to slide to a different position. But I can't remember where it was.
Make sure Bluetooth is enabled on the iPhone. Then connect to the Breeze via WiFi. Start Breeze Cam, go to Tasks, select Controller mode, power on the controller, Slide to Proceed, the controller should connect and vibrate, then slide to experience. You may have to slide through several help screens the first time you use this mode.
droneforce1
