Deleting flight logs?
Hi guys.
I bought a replacement H to replace my crashed one. Is there a way to easily delete the logged data from the old H?
Thank you in advance.
Pete.
A Factory reset will clear the old flight logs. It's generally a good idea to do a factory reset when the controller has been used by another owner. The reset gets rid of any weird channel settings or non-OEM apps that can create sometimes severe operating conditions. You just need to set it up again and rebind after reset.
Thank you.
I imagine the current firmware will not be lost. I was hoping there was a simple way. But binding is not a big deal.
Pete.
All done. Like new again. The only hiccup was I forgot the password for the camera and had to look it up. No big deal. Now if I can remember to add expo to the rudder stick, I'll be a happy camper. I made a new model so I could name it. All is good.
Thank you again. Take a couple of Attaboys out of petty cash. You deserve it.
Pete.
Just remember to create a new model, select Rud on the right side of adjustment menu first, and save your edits as you exit.
CKHD
