E30Z camera – torn wires
Hello. I have an E30Z camera for an H520 drone. As it has been dropped and some wires have come loose, could you please let me know which boards I need to solder the wires to (colours, diagram)? Could I also ask for instructions on how to replace the slip ring in this camera?
I have attached some photos below.
Yuneec swapped wire colors between CGo3+ and C23. It is possible from the little color I can see that the arrangement might be the same as C23. Getting it wrong would likely lead to permanent damage.
  1. What are the six colors coming out of the slipring?
  2. What color is the insulation of the remnant attached to "VBAT"?
  3. If there is any insulation still on the remnant attached to "TX", what is its color?
The colours of the wires on the camera are: red, green, black, brown, orange and yellow – I think those are the ones, as two of them are difficult to identify. Unfortunately, on the circuit board, the uninsulated wire doesn’t even have a small section left to help identify the colour. Below is a link to some high-quality photos:
Thanks for the info; around 7.00 pm EU time (which I suppose is Swiss time :) ) I’ll get on with the replacement and let you know the results.
Reactions: WTFDproject
Conversations
