Fpv and other mods?
Has anyone ever tried to do FPV with the H? I have some kylins that I use for racing. I'm wondering if I can receive signal between the controller and H? Has anyone else tried to mod their platforms?
There is no mod required. You simply connect with the HDMI out on the ST16.
You need to understand that the signal transmitted from the CGO3+ camera as actually a digital wi-fi signal which is not the same as other FPV style cameras which use an analogue video signal. You can pick up the CGO3+ video from any wifi enabled device that uses 5.8GHz but you will need software to interpret and display the video.
Yuneec's own Skyview work well on hdmi from the ST16.
MT Skin Clinic
