I bought the kit for the 3rd antenna, but there are no instruction manual.The FPVLR range extender has had varying reviews. Everything from "Great" to "Don't waste your money". The preferred antenna seems to be the Itelite DBS which is less expensive; $109 vs. $173. I don't think there is much difference it the range between the two. If you currently have an ST16 with 2 antennas make sure you order the kit which contains the internal coax to extend the 3rd antenna.
Brig 57I bought the kit for the 3rd antenna, but there are no instruction manual.
Where can I find this information?
Thanks
Thanks that's helps tremendouslyBrig 57
If you need to upgrade the ST16 to the third antenna watch this:
or this
Installing on the ST16 watch this
