Getting back into it.
About 6 years ago I boght a Breez and had a lot of fun with it, but other things got in the way and it remained in its box unti now, I got the app from the store without any trouble All this was before registration became necessary so it is still not registerered for now, I just want to see if it works, Tbe batteries ar dead and need replacing, They are the old ones that have 2 wire cconnectors not what seems to be the modern ones, So where can I get them?
The app pages all works as they shoukd, the screens work fine,
I used a large ipad with the virtual sticks but I forget now does it show on screen what the camera is seeing without the sticks or is it then a tap to get them back, memory is not what itused to be,
As I did some more disatant trips I thinkn the ringfencing is not there so will it be back wuth a host of updates that.that ar sure to be missing,
Any coomments will be much aooreciated. Thanks in advance,
.... what seems to be the modern ones, So where can I get them?
Breeze batteries are still available on eBay.
No updates have been issued for a long time. It is likely your Breeze already has the latest available firmware. When you get it powered up, you can post the current firmware to the Forum to see if an update is required.
Reactions: Pier2162
I'm in same issue with my Breeze. Has been stored for little over 1yr and I can't get the app! I used down loads I was sent from here and Yuneec skins but every build I've tried sayy my phone is not compatible! I have a galaxy A15! And if I'm not mistaken last time I used it was with A15! Does anyone have any suggestions or now if the down loads for the app don't work with A15 or is something blocking it that's turned on on the phone settings somewhere.
I’m not much when it comes to all the permissions in the Android OS, but it is likely you just need to allow the app permission to be loaded and allow WiFi to connection even though there is no internet.
Breeze Cam is a very old app designed for Android 5 or 6. Newer versions of Android think old apps are a security risk. Those that access the internet could be, but Breeze Cam only connects to the Breeze Access Point.
Reactions: WTFDproject
jonnyelectric
