H camera not binding
On the ST16 go to Pad mode, settings and wifi. Turn on the Wifi and see if the camera is listed.
You can also use the mobile app in order to verify a proper function. Just download the CGO app from either Appstore or Playstore depending on you device and connect to you camera like it was an ordinary WiFi.
Default password is: 1234567890
You can also use the mobile app in order to verify a proper function. Just download the CGO app from either Appstore or Playstore depending on you device and connect to you camera like it was an ordinary WiFi. Default password is: 1234567890
You can if your phone is dual band compatible. Using the ST16 does the same thing.
That is right but usually the mayority of phones will work. Using th ST16 is a little annoying in my opionion which made me switch to using the phone instat. It is just way faster.
Design 4Business Group
