H Plus Battery Source/Options
Anyone know of a good replacement battery for Typhoon H Plus model? Inquiry minds want to know. Thanks,
I’d go gifi power. At this stage finding new original batteries could be difficult, another issue with the original batteries is they will be some degrading depending on when they were produced, even if never used. To my knowledge gifi still produce small batches of new batteries so if ordered directly from the company they should be fresh. I’ve recently tested a different brand called vhbw, also a good option but gifi seem to be a more tried and tested brand amongst members 😉. Another option is generic 4 cell battery with a modified connector or a battery adapter in conjunction with a generic battery if u don’t want to modify the connector on the mainboard.
In search of Typhoon H plus battery replacements? Anyone know a good source?
I’d also recommend a good multi charger like a yuneec dy5 to balance and storage charge ur batteries, that’s if you don’t already have one. Batteries aren’t cheap so keeping them good as long as possible will keep u flying longer. Gifi also make an identical charger.
The dy5 is the most convenient if you only need to charge ur hplus batteries. If u want to charge other battery also look for a yuneec a10 with matching balance wires, that or a skyrc which looks identical to a10 but some skyrc chargers are quad vs dual like the a10
Yavor
