H520e-RTK stuck on 3D Fix with own RTK base — RTCM data received but no RTK convergence
Achterhoek, Gelderland, The Netherlands
Website
www.dutch-yuneec-drone-association.eu
Hi,
I've built a custom RTK base station (Raspberry Pi 5 + u-blox F9P) and connected it to my H520e-RTK via ST16E ground station over WiFi.
Setup:
  • NTRIP server: 192.168.4.1:2101/BASE0
  • RTCM output: 1004, 1005/1006, 1012, 1019, 1020, 1033, 1077, 1087, 1097, 1127, 1230
  • Throughput: ~300-400 bytes/sec (stable)
  • ST16E: NTRIP connected, shows "receiving RTCM"
  • Drone GPS: 31 satellites, good signal
Problem:
Drone remains at 3D Fix. No RTK Float or Fixed achieved, even after 5+ minutes of stable RTCM stream.
Questions:
  1. Does H520e-RTK require specific RTCM message types beyond standard?
  2. Any known antenna height / ARP offset settings needed?
  3. Should I use TCP (5016) instead of NTRIP (2101)?
Any pointers appreciated.
the point is:
My PI makes a own AP wifi network where my st16s is connected to, throug ntrip_caster from stefal. then from the st16s through ofdm to the drone. but that's not working perfectly. and in case there is no good support anymore for Yuneec in europa (Sadly) i dont know how to use it and what for things Yuneec needs for RTK..
Hi,
Setup:
Problem:
Questions:
Good question, but it's correct. 192.168.4.1 is the WiFi AP (Pi).ST16E connects as 192.168.4.147 (client) and reaches NTRIP on 192.168.4.1:2101.This is standard local network routing — works fine.
Conversations
