Hello from Switzerland, my name is Sacha. Je possède un Yuneec Typhoon H pro. Mais j'ai un gros problème avec la Gimball.
Salut à tous, quelqu'un pourrait-il m'aider ? J'ai un Typhoon H Pro, mais la nacelle ne fonctionne pas correctement. La transmission d'image et l'enregistrement fonctionnent, mais la caméra CG03+ n'est pas stabilisée. Le voyant vert est fixe. I have a video about this problem, but I don't know how to post it here?
Thank you 🙏
Hi everyone, could anyone help me? I have a Typhoon H Pro, but the nacelle doesn't work properly. Image transmission and recording work, but the CG03+ camera is not stabilized. The green light is fixed.
The most common problems, in order of difficulty, are:
1.) Sensor error preventing Initialization. (If gimbal is making beeping sounds, post the pattern or post the video)
2.) Stuck down/corroded contacts in the camera mount.
"Stuck Mount Contacts "
3.) Other break in the gimbal control wiring, including damaged slip ring.
"Typhoon H CGo3+ Continuity "
4.) Damaged gimbal board.
Thank you 🙏
Welcome to the group. Is this yours from fb .
Prototype
