Help please.
Hello All,
Want to know if the Breeze ONLY use the Yuneec controller? I've been told the gamesirg3s does not work Is there other options of controllers that works with the breeze?
Thanks for helping out.
Hello All,
AFAIK you have to buy Yuneec's controller. Possible reason is that Yuneec uses a proprietary Bluetooth API.
HTH
Hello STN6
you don't need Yuneec's controller to fly with the breeze drone because in the breeze cam app let you fly it with only your phone.
For more information about that you can check the youtube
it is possible to use that control even you have greater reach and better handling what you must do is:
1- connect your breeze
2 - go to FPV flight mode.
3- turn on control
4- select in the upper left tab control
5- in the bottom right appears an icon press it and your control vibrates
6- your control will be connected, now slide the bar and make sure you have video transmission
7- press start key for 3 seconds and go
8- The Y key is the option to fly home
happy flight
Reactions: CzarMark
yogaschoolinrishikesh
