Landing Gear
Just took the H for a short flight and the landing gear will not move up. Brought down close and watched. One side moves a little and the other side does not move at all.
Any suggestions on how to fix this.
Also, if you used RTH, and the landing gear came down automatically, during the flight you would need to switch it back to up then down again for it to work.
Did another flight a few mins. ago to watch it and all worked as normal. It must have been a problem with the connection. Tried it a few times and continued to work at it was made do.
Thanks for the suggestions and will keep them in mind if it happens again.
Reactions: ChadCloses
Glad to hear it. I've heard of other people having landing gear issues but I myself have not experienced any if it happens to you again I would test the switch in hardware and then if it appears to register properly I would then recalibrate the ST-16 in the secret menu.
when your gear doesn't work, try this...
power on your ST16....
power on the H with NO props....
Flip the H on its back....
Move the switch of the gear several times up and down.....
in most cases it will work again.
good luck with it.
greeting from holland.
scan02
