Lock cam on pilot in Angle mode?...
Bedfordshire, UK
Is it possible to make the camera lock on the pilot (ST16) whilst flying the H in pilot mode?
Only on my second flight, but was hoping this was possible?
Thanks.
Change to watch me. Ive done ot and the camera flipped around and pointed at me
Bill W.
So select Angle mode and Watch me and you're done?...the camera tracks you and the drone is completely under your control? I will try it. Thanks.
Sent from my LG-H955 using Tapatalk
From memory, follow me only works in smart mode.
Another alternative is to use angle mode and put the pan switch in the fully down position (global mode). This will lock the camera to the current orientation (point at pilot before moving the switch) and then the camera will stay orientated in the pan axis regardless of the direction of the H. There is no tilt lock position for the tilt mode switch at this time.
SemperSaint
