Hello All....
I was filming our local fireworks with my Typhoon H (third time filming Fireworks).
I was in Angle Mode and took it up to 450 ft and let it sit while filming the firework, no wind, and occasionally just moved the camera angle. LED lights off.
I got the first low battery warning, and then tapped the screen to turn off the warning.
The typhoon H then lowered its altitude to 249 feet.
Not 240, not 250, right to 249 feet.
My return to home altitude is set to 160.
I tried to make it go back to 400 feet, but it would not go back up.
I could go left, right, back and forward, down but could not get it back above 249 feet!
Landed and turned everything off and replaced the battery and took off and back to 400 feet.
Lost filming about 10 minutes of the fireworks.
Again when the low battery warning came on, the Typhoon lowered itself to 249 feet.
I looked for settings for low battery warning but can not find something for low battery warning settings. Where would I look for these setting?
This is the third time I have filmed fireworks and have never had this happen before.
Even when I just fly around I have never had this happen, or just have never noticed it.
I am going to go out later today and try it in the daylight and see if it repeats the lowering altitude.
Any Ideas Why this is happening?
