Mapping software
Is there any apps such as Drone Deploy, that is compatable with the Typhoon H? Several old posts from 2017 indicate the Drone Deploy was not going to make a version, but that was some time ago.
Reactions: frasafer
As I understand it, the smaller Typhoon H has no APIs for developers to use for an advanced mission planner like Litchi or Drone Deploy. The H 520 and others have mission planning software, not the original H.
Programming 'waypoints' for the CCC - Curved Cable Cam either in the air or with an app like CCC Editor or UAV Toolbox may do the job for you?
I tried these a few years back, am not sure of anything, and hope if this is misleading somebody who knows better will update us.
There is also a way to use the H520’s DataPilot (Windows version) to plan missions and import them into UAV Toolbox. The camera cannot be controlled through the program, and must be set to continually take photos. Overlap is controlled by flight speed and altitude.
Not the best setup, but does allow mapping to be done with the H480.
jonnyelectric
