Password for Special Tests
I seem to remember doing the tests years ago. I have not used my H+ for some time due to health.
I also seem to remember that the last time I tried I kept getting 'wrong password'. Same now.
I asked Yuneec about password, they sent me the default, which did not work.
I had no reason to change password, I do remember about the time I was trying to do the tests,
That there had been a solar flare. So I do not know if that corrupted it, but cannot get past the password screen.
Any one any ideas? Thanks
Some of the wording in your post leads to question if you are trying to access the hidden menu for calibrations or if you have a screen lock in place.
I don't know of any way to change the password for the hidden menu of the HPlus ST16s. Is this the password you were given?
y9u1n0e2eC
The password is case sensitive, and the "0" is the numeric character "zero", not the letter "O".
If you are actually having problems accessing the main screen (Screen Lock), that is a different issue, and the password above will not work at all. The guide to unlock the screen is:
ST16S Unlock for H Plus
No, the default password I was given by Yuneec was 0123456789 or it may have been the other way round.
Yes it is the hidden menu for calibrations I was after. I will try it later.
I must have had the password at some point as I had done the calibrations before.
The initial firmware did not require a password. It was added to later firmware probably because it is rarely needed and because some people had done it incorrectly resulting in warranty claims.
SuperBearAdventure423
