****, I can find H + Realsense modules left and right, but having a difficult time finding one for the H. I have been going thru the classifieds here, but a lot of them seem to be 2016, 17 threads.The RS v1 from the TH Pro will not work on the H Plus, so I suspect that the RS v2 for the H Plus is not compatible in the TH.
Yes. If you have the basic Typhoon H (H480), you can add the RealSense v1 to it. For normal flight there is little difference between RS and the stock sonar Obstacle Avoidance. Where the RealSense shines is in Follow Me mode or during an RTH when OA is turned on.So basically am I looking for the straight H realsense module?
It will avoid obstacles on its own. With just the sonar it will halt and wait for user intervention.Just curious.
What makes it shine
as you say in return
to home with Ob avoid
On ?
Keith Kuhn
When you say "Straight H" I assume your referring to the Typhoon H & Typhoon H-Pro, which are Technically Typhoon H480's, the Typhoon H-Pro came with Realsense, 3-Antenna Controller, and 2-External 2.4 GHz Antenna's Parallel to the Landing Gear Legs. People often mistake the Typhoon H-Pro for the Typhoon H-Plus, they are not the same and the Module from the H or H-Pro will not work on the H-PlusSo basically am I looking for the straight H realsense module?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
