Solution to skipping playback of edited TH 4K files in FCPX
I found out why that whenever 4K files from the TH skip after they have been edited. If you check the master files in Media Info or Sony Browse, the files show 29.97 when in actuality it seems that the CGO3+ may be recording at 30fps. I got rid of the skipping my manually changing the fps to 30 instead of using the native file settings.
Some for Adobe Media Encoder : Export/Encode only with setting "Based on source"
lakotadesigngroup
