ST16 Calibration
After doing all the calibration and hitting the reset button it failed most of them....what do I do now...
Did you follow a Youtube video on doing the calibration?
If the status light flashes green and white it means you are in Smart mode. Were you outside when you tried to fly?
I was trying to fly as I haven't been able to
Did you complete the first page of the calibration? You need to pass the first page before going onto the 2nd page tests. Also, did you center the two sliders before starting the calibration? And finally, did you move all the levers, switches and sliders full throw in all directions? If you did, then you should have gotten a green pass indication for each control.
You should also go to the Hardware Monitor page and check each of the controls to see if it shows anything not centered or if they only move a short distance or not. It the Hardware Monitor shows anything that's not correct, then proceed with the calibrations again.
shamrock@78
