ST16s not binding to H plus
I am playing around with an H Plus that will not connect to the ST16s. I have not tried to do any firmware updates yet, but will tonight.
When I first turn on the drone, the two rear lights blink blue. After turning on the St16s, it will not show up on the Wi-Fi. I can connect the controller to my home Wi-Fi, so I am pretty sure it is working.
So, I then tried a manual bind, by turning the drone over until all lights flash yellow ( I think). Then I click connect on the controller, and the lights stop flashing yellow, and the two rear lights flash purple.
But, even after doing the manual bind, I can't connect to the controller through Wi-Fi.
The DataPilot version is 1.4.4
RC Version is 0.35.0
Any thoughts?
The H+ does not use DataPilot the H520 does. Are you using an St16S that is setup for an H520 instead of an H+?
The aircraft binds via the SR24 2.4GHz Zigbee protocol. The C23 camera binds via 5.8GHz WiFi. If the camera is not being found on startup go into pad, WiFi settings and “forget” your home WiFi connections.
dnrgroup
