Problem with the controller for the H520 drone
I understand, but can't you still see what happens if you physically delete (clean) everything and then reinstall all the required (core) files to then update everything from scratch? What does ‘return to factory settings’ mean?
After this operation, I restored the files from the app given in the link above. Are these steps correct or should I just restore all files from the normal data pilot app?
"can't you still see what happens if you physically delete (clean) everything and then reinstall all the required (core) files to then update everything from scratch?"
I know of no home method to physically clean and restore beyond the factory reset you performed prior to the last update. That is not an actual reset. It is simply a clean-out of all user installed settings and apps. The only method I know of to physically clean and restore is the boot load process to install a new image. The boot load process requires an image we do not have, but some repair shops may. It also requires the proper software, the knowledge to set up and use it, and possibly a computer that is compatible with it.
"What does ‘return to factory settings’ mean?"
I can't see that exact phrase in the thread. Although it could refer to a Boot load, it most often is used to refer to the factory reset of the controller, which I think you performed prior to the last update effort. Did you run through this sequence prior to doing the update?
Well I don't know how but it seems to have worked, the second time after a previous reset and the installation of the files from your file. Only there is another problem - every time I turn on the drone and the camera it takes quite a long time to connect and every time I have to manually select the thermal camera. How do I connect them permanently?
"it takes quite a long time to connect"
I am not much familiar with H520/CGoET combination, but most EU firmware takes a lot longer than the same camera on US firmware. If you will time the evolution and post the actual time it takes, someone more familiar may be able to comment whether it is normal or not.
"I have to manually select the thermal camera."
By this, do you mean you are having to go to settings/WiFi menu and manually bind to the camera every time?
A fresh screenshot of your versions page would also be helpful in understanding the status.
Once you have connected to the Wi-Fi of your cell phone or router, the remote control will automatically access this Wi-Fi again and again instead of the camera. To prevent this, you must deactivate the WLAN or hotspot so that the remote control can access the camera directly.
Subject CGOET... Which firmware is installed... A or E?
If the E (Europe) firmware is installed, it is normal that it takes up to 3 minutes.
Mihal05
