The most I get is 8 or 9, maybe 11 once or twice how many on a regular basis do you all get flying in the same general location, and weather conditions ? Whats your norm ?
Never mind I was looking at the OBS, the one before the SAT's, what confused me is the numbers thinking it was for the controller, and the next was the drone itself ?On the ground, I’ll lift off once I get 15 or 16, even when UAV Forecast is telling me only 11 - 13 are visible. Once in the air, I am typically seeing 17-20.
Northern Wisconsin, USA
46 degrees north
I seem to always get fewer satellites on the transmitter than the H Plus. Always turn on the transmitter immediately after taking it out of the backpack because it takes so much longer to acquire sats.Never mind I was looking at the OBS, the one before the SAT's, what confused me is the numbers thinking it was for the controller, and the next was the drone itself ?
Whats funny is the breeze acquires 12 sats in 1-2 seconds, whats up with that ? Are you talking about the first bird icon, if so thats the OBS, thats the one that confused me ? Now that i just read a reply from steve c I guess I was wrong again ( I'm getting good at that ) seems thats the controller ? It doesn't take much to confuse meI seem to always get fewer satellites on the transmitter than the H Plus. Always turn on the transmitter immediately after taking it out of the backpack because it takes so much longer to acquire sats.
The third and fourth icons are your sat indicators. Third one is transmitter, fourth is HPlus sat indicator.Whats funny is the breeze acquires 12 sats in 1-2 seconds, whats up with that ? Are you talking about the first bird icon, if so thats the OBS, thats the one that confused me ? Now that i just read a reply from steve c I guess I was wrong again ( I'm getting good at that ) seems thats the controller ? It doesn't take much to confuse me
Whats the function of the SAT's on the controller, as its usually @ 8, or 9 in yellow, only 2-3 times it was @ 11 green ?The third and fourth icons are your sat indicators. Third one is transmitter, fourth is HPlus sat indicator.
It uses it for the return to home. Unlike other UAS's that use a GPS location as their return to home position, the Typhoon H uses the location of the controller (ST16) as it's return to home.Whats the function of the SAT's on the controller, as its usually @ 8, or 9 in yellow, only 2-3 times it was @ 11 green ?
He is using the H Plus and like the H520 the Home Point can be set as a GPS Position or the position of ST16S controller at the time RTL is triggered. This is found in the settings menu for the ST16S as the RTL setting.It uses it for the return to home. Unlike other UAS's that use a GPS location as their return to home position, the Typhoon H uses the location of the controller (ST16) as it's return to home.
