ST16S with Typhoon H drone ?
Hello to all.
Can anyone confirm if ST16S controller can be used/paired with Typhoon H drone ?
Of course I know that software for ST16 (typhoon h) must be installed but question is can we use ST16S as hardware with Typhoon H.
If this is possible, where I can find software and manual how to do this.
Simply yes...
Check the topics in the forum or await a bit and help will come.
Reactions: dxer
Hello to all.
Of course I know that software for ST16 8typhoon h9 must be installed but question is can we use ST16S as hardware with Typhoon H.
Converting ST16S to ST16 is fairly easy. But it's also easy to mess up anything if it's the first time you've done it. If you mess up and have to convert ST16 back to ST16S it is a much bigger deal. Please ensure you understand the guidance and ask any questions you have before you start. Then proceed at your own risk.
Reactions: dxer
Jimmyray
