To discover CCC
Kozloduy, Bulgaria
I'd like to ask all of you to do some disvorer how actually the cable curve cam works.
Is the ST16 sends a command "go to and do" or all the time send imitated sticks commands?
Due to probably only possible point to add some automation this knowledge will be valuable. Also automation from CGO3+ should be checked.
Unfortunately I have no time and place room to do this for us.
go here for an online editor... CCC editor for typhoon H - by Eric EMMANUEL
also the file is text... you can read it in notepadf before putting it on the st16
Vaklin,
Yes to your question. The ST16 software interprets the waypoints (in a text file as listed in the CCC editor as noted), and interpolates a curved path between waypoints for a smooth motion. All of the flight commands are sent to the Typhoon H as "imitated stick commands." Those commands include the CGO3 pitch and the "yam" which is the camera yaw. Photo and video selection and shutter/start-stop commands are manual by the usual ST16 buttons.
Jimmyray
