Typhoon H Pro RealSence came already attached
hello, im new here but have had this drone for years but was put away, im looking for the latest update for the drone and controller ? any help would be great
It has also been years since the last update was issued. You may want to bind the drone and camera to the controller, then compare the firmware versions page with the attached image of the latest Typhoon H Firmware.
If the firmware is already current, there is no need to update.
Regardless of the version, if the drone is working normally and does everything you need it to do, there is also no need to update.
Please consider Yuneec updates do not always go as planned. There are many threads on the Forum trying to recover systems that were bricked doing updates that were not needed in the first place.
With all things considered and you still want to do an update, this link will take you to the latest firmware:
Customkcupboxes
