Unbrick your ST16s
NorCal
Early this morning, I downloaded the new firmware and in the middle of remote downloading process the controller was stuck in 56% and all of the suddent ST16s rebooted itself and error messages appeared "unfortunately, the android process has stopped" and the second message "unfortunately, launcher has stopped"
I ran into this write up.
Advanced User Info, including SDK
If you tap rapidly 5 times the Advanced Menu will be available. DO NOT do this except under the direct direction of authorized Yuneec Techs. It is all too easy to make accidental changes that brick or crash the craft.
The ST16s was able to complete the download and the method helped debrick the controller.
‘‘Twas more of a home WiFi issue, as well as an Android issue if any downloaded data is interrupted.
Rank Li
