Video not recording video
Recently bought a refurbished Typhoon H but the video will not record. It works on my other Typhoon H. Takes still photos and flies fine. Any suggestions?
Have you checked the video push button in Hardware Monitor?
You could try to spray Electrical Contact Cleaner (the type that says Safe for Plastic), on the button. I don't know if it will penetrate into the switch without opening up the ST16. Try spaying it several times while operating the switch.
Yuneec Typhoon H will bind to my receiver and the props will turn when I push the start button, but then it will not fly. Any suggestions?
Back to Hardware Monitor. Do the sticks and the rabbit/turtle slider work properly? Do they go full scale and return to exactly zero? Do you here any rapid beeping from the controller?
Jkent8541
