Yuneec H+ ST16S Replacement 2.4GHz Antenna
Chios, Greece
Hello,
Can someone direct me what antenna type is needed for the ST16S 2.4GHz link?
I usually fly my H+ with my 4Hawks SR antenna but I would like some stock 2.4GHz replacements because the ones included with my ST16S have some kind of fault because they do not find any available networks when I use them.
The ST16S is working 100% fine with the 4Hawks SR unit but as soon as I switch to the stock antennas (I always switch antennas with the ST16S powered off), I cannot connect to the aircraft.
Many thanks in advance.
They are standard 2.4GHz tuned omnidirectional antennas for the two outside antennas. They connect to the SR24 module used for Zigbee RC control.
The center one is a 5GHz tuned clover leaf or patch antenna for WiFi communication with the camera.
Reactions: Frontier
Thank you for your reply.
Is it RP-SMA or SMA?
Sacha
