Yuneec Pilots Locations Map
Bonjour,
Merkav
pilote typhon H
POULIGNEY-LUSANS 4 rue du stade 25640 FRANCE
pos: + 47,32905, + 6,20132
point bleu standard
@merkava
Veuillez vous assurer que votre nouveau point est comme vous le souhaitiez. Faites-moi savoir si des changements sont nécessaires.
Translation:
Please ensure your new point is as you wanted. Let me know if changes are needed.
Use this link to view the Yuneec Pilots Location Map - Google My Maps.
To add (or change) your Yuneec Pilots Location Map information, create a new post in this thread with the following information:
1. Your member name, as you wish it to appear on the map.​
2. If desired, add a short description that will appear when your point is selected. The description can include an​
image, if you add the image to your post.​
3. Your location. Many members chose the city/town of residence or a nearby landmark. Location can also be​
provided as a street address, Zip Code, or GPS coordinates.​
4. Choose the appearance of your map point. The standard point is the blue symbol seen most often on the map.​
You can use this style, including different colors, you can choose an icon and color from the selection below,​
or you can upload a custom icon file to your post.​
5. Please add anything else that can help us create your point the way you want it.​
ALL members are invited to post your location on the Yuneec Pilots Map
Available colors and Icons:
1. Paolo drone operator
2. Agronomist
3. Viale Domenico Rivalta, 15 - 40026 Imola (Bo). Italy
4. Yuneec H520/CGOET
5. .
@paolo negroni,
I do not know how I missed your earlier request for adding your point. My apologies.
Please check your new point to verify it is the way you want it. Let me know if changes are needed.
Non so come ho mancato la sua precedente richiesta di aggiungere la sua osservazione. Le mie scuse.
Si prega di controllare il tuo nuovo punto per verificare che sia il modo in cui lo vuoi. Fatemi sapere se sono necessarie modifiche.
zaim
