Yuneec Pilots Locations Map
Bigrhs
Typhoon Q500 4k & Mantis Q pilot
152 Jamestown Ln Cedar Bluff Va 24609
Standard blue + custom Icon E
Reactions: DoomMeister
Big RHS,
The street address did not work. I temporarily placed your mark where the zip code centered. If you will provide a GPS coordinate, I can place the mark where you really want it.
Otherwise, please ensure the mark is the way you want it.
Big RHS,
Where my mark is is less than a mile from where my home is so it is fine where it is.......Thanks
Reactions: WTFDproject
Tom,
Please check your point to ensure it is the way you want it.
Tom B.
Yes, Tom the location is correct for me in Stuart Florida. I am surprised there are so few Typhoon H flyers in Florida. I see we now have the opportunity to try out the beta version of the UAV toolbox. Thanks for setting up the map locations for us on the forum.
2ND EDIT: I've moved again. @WTFDproject, sending you a DM so that my position may be updated. Thank you sir!
EDIT: I have moved. Will send you a DM in addition to this edit, @WTFDproject
Please update my position on the map:
1) Sherwood McGowan (Massive:Ronin/SKeM77)
2) Typhoon H Pilot and Aerial Photographer
3) Location: Rolla, MO. Now located in St Louis, MO USA.
4) Standard blue point
Please add me to the map:
1) JWG
2) Typhoon H pilot
3) 42°28'58.9"N 122°57'08.2"W
Thank you!
Please change my map info as follows:
Currently: Riktar Q500
Change to : Riktar
Add description: Q500 and Typhoon H
Change picture to use my forum avatar?
Thanks!
markcareengi
