3 color plastic cover
Supposedly to mount on rear of drone. Can’t find where it mounts IMG_0214.jpgIMG_0215.jpg
Turn the drone on its belly, it mounts below the battery compartment.
That's where mine is.
It’s pretty hard to understand what you’re talking about when you can’t find a means to describe it.
The three pictures do not depict a three colored plastic object. One appears to be the back of a laptop, one an H with an empty battery bay, and the other a plastic cover. Two of them on a red mat.
The Cover in your first pic is just that, a Cover. It's purpose is to cover the Wire Connection used to connect the RealSense Module to your H. As a previous reply stated, it mounts over the connector at the back bottom of the H.
Ok so, That is the stock lamp cover for units without the RealSense module. It has to be removed to install the RealSense module.
The RealSense module replaces the stock lamp cover; it literally sits on its place on the rear part of the aircraft.
Your aircraft already has RealSense installed, ergo, it has replaced the stock "3 color plastic cover"
Store that cover, if you wish to uninstall the RealSense module you will need that to, ehm, cover the hole it will leave in its place.
Heres an image showing where it would go.
Reactions: Grumpy
x640536786
