So I looked at the Inspire 2 and one feature I like is to have a second camera for 2 person operation . So I got to thinking and I was wondering is I could add something like the Boscam 5.8 or would that cause problems with the Typhoon radio?
I've seen multiple Lightbridges going at one, so I assume just two signals on varying bandsI wonder how DJI does it on the Inspire 2
This is cool, what is your setup for the FPV + receiver?Yes. I've modified a cgo3+ so it also has a fpv cam and vtx onboard. It can be swapped out between craft so I can fly with or without it. On the st16 I have a second screen mounted so I can see the video from the camera.
Hi, I use Aerial photography with Robinson R44 based at Bromma Airport Stockholm as my clients want to see the video while filming. I have connected the Feelworld to the ST16 with a 5 meter HDMI cable so the client don't have to climb on my shoulders while I operate the H/ST16 and cam. Works great! Then you can also watch the ST16 replay on the bigger Feelworld 10.1" screen.I use a Eachine diversity monitor mounted above the st16, that way I have both the fpv feed and the cgo3 feed visible while flying.
