After Crash, no communication between E90 and H520
Hello All,
Recently i crashed the H520. The damage was 1) The cables which are located between camera and H520, were broken. 2) One of the motor arm was broken.
I repaired motor arm and cables. Then i connected the camera to H520 and started. First, the problem was i could not control the gimbal movement.I had a live stream , all connections and i could control the tilt but i could not control the gimbal.So i decided the change the board and gimbal motor. The result is bad. Now i have only live stream. I do not have any connection except camera. I can not even connect the H520.
I could not figure what is the main problem. I need help about that. If you guys do not understand what is the problem , i can give more detail.
Waiting your commends.
Thanks all
paulrs
