i chipped a prop, decided to order replacement props from amazon and got sent these... would you guys use them? i only need one, the weight feels less than the originals and a bit more flexible than the original. should i try them out or get a refund?
Hello kiinglouie325..........by now you've made your purchase either way. I also purchased after-market propeller's whose appearance were very similar to the condition of your photo"s.
I examined them and knowing the weight was not an issue, and that the blemishes on the tips of these were merely a manufacturing defect and YES, mine appeared "little bit more flexible" than originals Yuneec Props....however I STILL attached these and flew with them AFTER balancing these. They worked "just fine". While having/using original Yuneec props may be fine, after market props have not let me down in my experience.
As you no doubt have found out by now, ALL props either originals or after-market won't always be "balanced". On one occasion, couple of props I purchase had "interior threads" NOT quite
"machined out" so what I did to correct that, was to use BOTH a left hand & right hand TAP (8 x 1.0 mm) (for my 4K based on month/year manufactured). After this minor effort.....they performed
quite well...no issues. Spending money "needlessly" on some parts....appears to be a "run away freight train" for some. I'm not "Mr. know it all", but I do have a measured level of experience that
has proven my methods and processes have worked out well, in that with past experiences, as gone on to "build & develop" and validate my "confidence level" in making decisions related to various purchases and adjustments to these UAV crafts when and as needed. Hope this helps!,,,,Have a good one!!
