Arm motor bracket
Does anyone know if I can order only the bracket with the clips separated? I I have 4 arms with only the brackets broken. All the rest is still intact. It's stupid to buy a complete set. Does any know? Thx
If that piece is broken, the bottom shell is often broken as well and sometimes the sub frame. I just rebuilt one with similar damage. Had to replace top and bottom shells, frame and 3 motor arms.
This is the only reason I should change it. Left is original, right the broken one. It is about the screw hole.
I fixed it with some kind of metal pasta. It's stronger than the original.
[/QUOTE]
sunwininstitute
