Auxiliary supply
Discussion in 'Q500+ Discussion' started by Painternz, Dec 10, 2015.
  1. Painternz
    Is it possible to remove the camera cable from the body and fit a servo to use for fishing, fitting another cable and use the toggle switch for camera as a power supply to servo?
  2. Fleamac
    West Michigan
    Fishing???
    I WANT VIDEO OF THIS!
    :D
    clackey likes this.
  3. Yuneec_Usa
    Ontario, CA
    Search youtube "drone catches fish" there is a few videos.
  4. Fleamac
    West Michigan
    Yep, I've seen some with the fishing line just hanging. But I don't think I've seen one with a servo twitching, pulling, or reeling in the line.
    That's what I'm looking for.
  5. Rnlcomp
    Would suck if the fish pulled the drone under :eek: I'll keep my rod-n-reel.
  6. Painternz
    B4 you all get too excited I am looking at taking line and weight out 100mts + and need a release pin hence servo. Maybe Yuneec can answer the question. Fish size would b far to heavy for quad, might have a go at bait fishing with it
  7. John Locke
    In the US, it's illegal to drop things from a flying craft, that may be why someone hasn't invented a drop device accessory. I've looked for a drop device for my craft but can't find anything to adapt that's simple and cheap. I want it for search and rescue, dropping a cellphone, dropping a leader string to ropes, dropping medicine/bandages, etc. A drop device has got to be an easy thing to design. Just look at the proto X nano quad, those are $40 with controller and you can fly those 100 meters away. Wifi can easily go 100mts outdoors. If someone invented a clamp on drop device that was self powered, rechargable, and operated 100mts away with a simple little thumb drive sized trigger, they would make lots of money. I think there's a huge demand for that, even though it's illegal. I think the feds are concerned about dropping drugs, guns & ammo (in prison areas) from the air, which would cause chaos. Even so, I expect someone, someday, to offer a light-weight wireless drop device, ideal for drones.
  8. Painternz
    I'm not 100% sure on the legality here in New Zealand but there is a company that has made a base plate with servo for a dji phantom 2 using the controller auxiliary. Mounted where gimball would normally fit.
    Weight is loaded through release pin.
  9. Az Nick
    Mesa, Arizona
    I for-see another Bruce Willes Die Hard Release – Die Hard 4 “PRISON BREAK” LOL
