I found this forum a couple days ago as I was searching for alternative power sources for my typhoon H.
Basically I'M modeling a case to 3d print and I've ordered some of the power dean t connectors to integrate into the 3d print and hook up a 4s lipo battery into it. The goal here is to produce a replacement battery compatible with the H that can potentially increase flight time and decrease charge time.
Does anyone want to collaborate on this? I'm developing the battery case in AutoCad a a two part assembly.
If this already exists let know. I'd also like to know if a battery like a multi star wih the following specs will keep the H in the air safely. I've read that the multistar discharge rate is pretty lame compared to the nano tech.
It's 63 bucks
Specs:
Minimum Capacity: 5200mAh
Configuration: 4S1P / 14.8V / 4Cell
Constant Discharge: 10C
Peak Discharge (10sec): 20C
Pack Weight: 433g
Pack Size: 142 x 49 x 29mm
Charge Plug: JST-XH
Discharge Plug: XT60
It's 63 bucks
Specs:
Pack Weight: 433g
Charge Plug: JST-XH
