Battery Charger
Ok I have a Battery charger and I am unsure if it is safe to use on the Q500 4k Batteries.
Here are some pics.
It will probably work using the 11.1v port on you balancing connector. However, it only has a .7 amp output so it will charge pretty slowly. That charger is actually made for Li-ion batteries and not Li-po's. I generally charge at 2.5-3.0 amps and some people charge at over 5 amps.
If you decide to try it, disconnect it immediately after charging is finished.
Personally, I would look into another charger.
One made for what you have.
Lipo's are not something to "experiment with".
As Steve mentioned... you'll be waiting forever to charge the batteries. What I can do in one hour would take you 7.14 hours with that charger.
Jmo thanks and good luck,
Jafo
Yeah I was just checking
I am not going to use it I just wanted to make sure if in a dire situation it would be safe to use.
paulrs
