battery issues
Dear all,
I have problems with the batterys. I have a Chroma Horizon. When I place the battery inside the drone and I start to fly the St10+ controller give me a warning that the battery capacity is low and I have to go down. This happens after 3 a 4 minutes. I use my gimball as well. During the flight the red battery LED is not blinking.
I start my flight with a full battery.
Do I need to replace the battery?
Thank you in advance
Yes. You need a new battery.
What you describe is typical of a battery that is beyond it's service life. They will charge to full voltage, but there is no real capacity left in the battery. It becomes risky to continue using the battery when flight time is down this far. The battery may suffer catastrophic failure when under load (in flight) or when being charged.
xbytesolution
