Battery problems
Buenos Aires, Argenina
Hello, my name is Jorge and I have a big problem with drone batteries. The batteries are not loaded and they are swollen, they only had 20 charge cycles. Someone had the same problems or someone knows who to consult on the Yunnec website. Thanks so much
The most common cause of early battery failure is improper storage. Storing in the drone or in the charger is bad. Not placing the battery voltage to storage charge, and periodically maintaining the storage charge, will also result in battery damage.
Can you tell us something about the history of the batteries, such as how old, how long has it been since they were last used, and how they were stored?
Reactions: Grumpy
Rank Li
