Yes its a new drone with new battery's in the box.New batteries?
Did you try both batteries in the drone to see if they fire it up?Yes its a new drone with new battery's in the box.
yes i did. the bad battery wouldn't let the connection program on my controller work cause it say that i only had 6.5 volt in battery life. then i put the other charged battery replacing the bad battery and the function where working good on the controller and the drone itself.Did you try both batteries in the drone to see if they fire it up?
