thank you,If a prop is out of balance, over time it can cause structural defects to other components of an aircraft.
Is the H used, or have you had it since brand new?
According to pilot, prop bent, arm broke, and drone fell from 60m. Crashing and splitting appart several piecesSo, this motor and prop just fell off the aircraft?
And I have a doubt about origin of accident so I ask:
"Can this happen during stationary flight without hitting anything ? (with non-original props) "
I doubt it, he either hit something or something hit it causing a crash.And I have a doubt about origin of accident so I ask:
Most likely one motor stopped and when it came down on the sand (guessing it crashed on sand because of the picture) bent the prop. There does not appear to be any damage to a leading edge of the prop, just a bend. To me that indicated it bent when it was not spinning. In order for this person to get a better answer, they need to join and ask questions and post replies. Going from you, to us, to the owner, to you, to us, is just too many people involved.
Could be bent on crash, I guess Yuneec hexas can fly with 5 motors, so one stopped, couldn't cause the crash. Why did it fall ? See log files above.Most likely one motor stopped and when it came down on the sand (guessing it crashed on sand because of the picture) bent the prop. There does not appear to be any damage to a leading edge of the prop, just a bend. To me that indicated it bent when it was not spinning. In order for this person to get a better answer, they need to join and ask questions and post replies. Going from you, to us, to the owner, to you, to us, is just too many people involved.
Stationnery flight means no movement in any axis (X, Y, Z) relative to ground,Clearly not enough information. That damage most likely happened on impact (spinning props or not) as opposed to in the air not hitting anything during "stationary flight".
Define "Stationary Flight". That sounds like hovering. Can this happen while hovering? Not until the laws of physics change. Next question please.
Stationary = no change in x,y, or z axis, relative to ground.Clearly not enough information. That damage most likely happened on impact (spinning props or not) as opposed to in the air not hitting anything during "stationary flight".
