Breeze balance charger
Does anyone have a hack to be able to charge the batteries with an aftermarket balance charger?
In general the “hack” is mating the 4 battery terminals (3 cells) to the charger balance port. You just need to figure out how to get the battery terminals out to the charger. No easy way (mating adapter) but can be done. The better chargers allow charge current to be programmed and if you have one of these I assume you know how to use it and the precautions necessary for safe charging.
Patynowy
