What phone and version of Android is causing the issue with the controller?Still no effect.
What device and version of Android is working properly?
Its unbelievable, controller work properly and simply connects to phone only if GPS is turned ON (in phone settings).What phone and version of Android is causing the issue with the controller?
Yes, I turn on GPS location services in mobile phone settings.Are you referring to the GPS location services on the phone or the GPS on the Breeze?
Thank you for your, technical insightHi, I've had problems with the controller for a long time.(constantly received the answer "fail to connect"). But it used to work great on my phone. Then I tried to connect on two other devices and everything connected well.
I conclude that Android phone updates sometimes change the protocols of bluetooth, so there are problems like ours.
English with Google Translate)
I will send you the file tomorrow morning. It is on my computer and I am not able to access it right now. This file from YuneecSkins downloads may be the same I have saved on my computer you can try it. Breeze FPV SoftwareHello Doommeister,
I have tried to download the update for the breeze transmitter for another one that I am trying to sell. However, the download is not available on Yuneec's website anymore. And, I wanted to know how you managed to get the transmitter that was sent along with my breeze to work properly. Could you please provide me the link or download you used to this? Thanks.
Also, can you provide me step by step instructions on how to extract and/or download the file properly. Thanks again!The first post in this thread for background and instructions.
The warning is likely because there is an .exe file and it is not signed for the download on the YuneecSkins website. I may have gotten the same warning from Win10 when I opened the file. If you feel safer I’ll upload it from my computer in the morning.Breeze G3 Controller Update - Updated 10/15/2021
I’ve seen several posts dealing with the G3 controller not controlling the camera gimbal or wondering where the update is located. The following link will take you to the download on the Yuneec Skins website. Unzip the file and read the pdf file for the instructions, but use the instructions in...yuneecpilots.com
I just remembered that I have that file in my Dropbox. Here is the link Breeze_Controller_Update.zip
Awesome to know thanksCorrect. You need to go into settings to connect WiFi, but not Bluetooth for the Breeze Controller. With Android it helps to be in Airplane mode on the phone to disable the cellular connection, but enable WiFi and Bluetooth.
This thread will help to identify any issues with the startup and connection sequence How To: Troubleshoot the Breeze and Request Help in the Forum.
The other thing that comes to mind is to make sure you have the controller in the proper operation mode for iOS or Android. To set for Android power on using “Power+A” buttons, and for iOS power on using “Power+Y” buttons. After setting the mode you can power on and off just using the Power button.
