Breeze reset
My Breeze loses connection with my phone and now it won"t reset. On boot there's no flashing light light in the front motor arm. Is it DOA?
Do you get any LED in the front arm?
It should be white at power up then turn red. It should then go to a flashing green when it starts broadcasting for WiFi connection.
When you power on do you get the rising tones with the rear LED flashing red/green/blue then changing to a flashing blue?
If you connect the Breeze to your computer with the USB cable are you able to see the internal memory of the Breeze?
No lights at the front arm anymore
get rising tones and the rear led flashes red/green/blue then flashing blue
Computer doesn't see the internal memory of the Breeze
Sounds like the internal memory was formatted by a computer instead of through the Breeze Cam app. Without being able to connect via USB reloading the firmware is impossible. You will need a new A9 board. You may still be able to find one, but don’t pay for it than a used Breeze. Many are priced from when the Breeze first came out and cost $250 to $350 (the Breeze was $800).
bluie707bayboy
