Can I test battery cells
I have a yuneec H drone.
Is there any way to check each individual cell on a battery ?
See the attached picture.
Thank you
Mike
See the attached document
  • Power4 battery terminals.pdf
Thank you for your quick response.
I am sending you 4 pictures of battery tester that I use for my RC cars.
Can I use one of these to check each cell?
If so how do I wire it to work?
Thank you for your help.
Mike
Sorry forgot the photos .
You can use an adapter cable like this one, and plug the balance connector into your tester. 0E7D0B49-A120-47DC-8108-9E2275CFD805.jpeg
Otherwise just use a multimeter to check the voltage of each cell according to the document.
Reactions: Cecil
The adapter you have in your reply will work. Where do I get it? I have not been able to find it. Thanks
Mike
Mike
Check YuneecSkins.com or GiFi Power. Make sure you get the one with the spring loaded round pins for the balance leads used on the H480 batteries.
The H+ and H520 use the rectangular miniDeans in those positions and will not work.
Reactions: Cecil
apalomba
