CCC editor for Typhoon H
I have been using the 'CCC editor for Typhoon H' this evening but have issues SAVING a file.
1) If I open and existing downloaded from my ST16 and edit it, I CANNOT SAVE IT.
Clicking 'Save' opens a small dialog box stating 'ATTENTION PLEASE' with a 'Close' button.
2) If I create a new CCC path, clicking 'Save', produces the expected 'Save your mission file' dialog.
QUESTION: Is it not possible to modify an existing CCC path and 'SAVE' or 'SAVE As' the file?
If you can, am I missing something here.
The 'CCC editor for Typhoon H' shows the path as being Point-2-Point between way points.
The CCC actually fly's the path as a SPLINE CURVE. Is there any way to get this editor to show the
CCC path as a Spline Curve?
They Typhoon Flight Planner H - Does display the path as a spline curve. I would not agree that it is
an accurate spline curve, but it does show one.
I have read google results where pilots expect the CCC path to be a sharp Point-2-Point path.
Displaying the Spline Curve path is necessary to display the actual path especially if your path involves
flying between houses or other tight obstacles.
dubiousflyer
