- Joined
- Jun 23, 2018
- Messages
- 5
- Reaction score
- 1
- Age
- 26
HELP!
Right so, tonight I set out for a little flight literally round a 1 acre garden, all checks done before flight and did a compass calibration, used my first battery h flew spot on second battery I took off retracted gear and went to fly forwards away from myself when the h suddenly flew to the right in a long sweep no inputs would correct the direction of flight I went straight into panic looked at all the switches to check the positions of them I was in angle, obs off, gear up, throttle right back. I then put it into Home, it said it was in Home mode but kept flying away, the gimble was doing its own thing spinning around kept losing and getting picture to the st16, even trying to drop the altitude would not work. at one point it was a tiny tiny dot in the distance no inputs what so ever would bring it back, knowing the local area well I could sort of see where it was catching split seconds of video when the gimble was pointing down, then lost all contact with it screen froze so drove to when it roughly was (near a friends farm about 1.5miles down the road) at which point walking through field, we hear the beeping of h then connected back to the h, the st16 was telling me the battery level low and down to 5 motors, seen in the distance it was in the hedge row of a field, where it had dropped onto my friends digger and bounced into the hedge, it is a complete write off I should think see pics, need help to know what to do from here, anything would be a massive help, in the uk! Thanks in advance
